2 做過哪些操作或改動(dòng)設(shè)置等
[教程] wddns 1.8的手動(dòng)升級(jí)
如果手動(dòng)不能升級(jí)wddns,可使用手工升級(jí)如下
SSH登錄服務(wù)器
cd /tmp
wget -c http://down.wdlinux.cn/down/wddns_v1.8.tar.gz
tar zxvf wddns_v1.8.tar.gz -C /
這樣就完成了
然后在phpmyadmin里的wdcpdb數(shù)據(jù)庫里執(zhí)行如下的SQL
  1. ALTER TABLE  `wd_dns_domain` ADD  `ngid` TINYINT( 4 ) NOT NULL DEFAULT  '0' AFTER  `gid`;
  2. ALTER TABLE  `wd_dns_update` ADD  `ngid` INT( 8 ) UNSIGNED NOT NULL DEFAULT  '0' AFTER  `pid`;
  3. ALTER TABLE  `wd_dns_records` ADD  `ngid` TINYINT( 4 ) UNSIGNED NOT NULL DEFAULT  '0' AFTER  `pid`;
  4. ALTER TABLE  `wd_dns_monitor` ADD  `bid` VARCHAR( 50 ) NOT NULL AFTER  `bip`;
  5. ALTER TABLE  `wd_group` ADD  `level` TINYINT( 2 ) UNSIGNED NOT NULL DEFAULT  '0' AFTER  `name`;
  6. UPDATE  `wdcpdb`.`wd_group` SET  `level` =  '10' WHERE  `wd_group`.`id` =10;
  7. UPDATE  `wdcpdb`.`wd_group` SET  `level` =  '1' WHERE  `wd_group`.`id` =1;
  8. UPDATE  `wdcpdb`.`wd_group` SET  `level` =  '5' WHERE  `wd_group`.`id` =5;
  9. ALTER TABLE `wd_member` ADD `pid` INT( 8 ) UNSIGNED NOT NULL AFTER `gid` ;
按上述操作over,sql語句第九行執(zhí)行錯(cuò)誤,wd_member表中已經(jīng)存在pid字段...
后臺(tái)顯示升級(jí)成功.
桂商網(wǎng)
順便說一句,升級(jí)為1.8后,部分功能被禁用了,需授權(quán),可以理解...
桂商網(wǎng)
不影響正常使用就可以
功能那個(gè),之前的版本也是有限制的,只是提示不一樣
回復(fù) 4# admin
   老大,杯具啊,使用不了了,升級(jí)后添加域名報(bào)錯(cuò),少了一張表,怎么卸載重裝?#1146 - Table 'wdcpdb.wd_dns_buylog' doesn't exist
INSERT INTO wd_dns_buylog( uid, pid, domain, money, note, rtime )
VALUES ('1', '0', 'gxsme.net', '', 'smegx 開通產(chǎn)品ID 0 域名為gxsme.net 總共元', 1352470706
桂商網(wǎng)
  1. CREATE TABLE IF NOT EXISTS `wd_dns_buylog` (
  2.   `id` int(10) unsigned NOT NULL AUTO_INCREMENT,
  3.   `uid` int(8) unsigned NOT NULL DEFAULT '0',
  4.   `pid` int(8) unsigned NOT NULL DEFAULT '0',
  5.   `did` int(8) unsigned NOT NULL DEFAULT '0',
  6.   `domain` varchar(100) not null default '',
  7.   `money` float(10,2) unsigned NOT NULL DEFAULT '0.00',
  8.   `note` varchar(100) not null default '',
  9.   `state` tinyint(1) unsigned not null default '0',
  10.   `rtime` int(10) unsigned not null default '0',
  11.   PRIMARY KEY (`id`)
  12. ) ENGINE=MyISAM  DEFAULT CHARSET=gbk AUTO_INCREMENT=1 ;
  13. CREATE TABLE IF NOT EXISTS `wd_dns_paylog` (
  14.   `id` int(11) unsigned NOT NULL AUTO_INCREMENT,
  15.   `uid` int(11) unsigned NOT NULL DEFAULT '0',
  16.   `trade_no` varchar(50) DEFAULT '',
  17.   `out_trade_no` varchar(50) DEFAULT '',
  18.   `money` float(10,2) unsigned NOT NULL DEFAULT '0.00',
  19.   `title` varchar(100) DEFAULT '',
  20.   `note` varchar(255) DEFAULT '',
  21.   `acc` varchar(100) DEFAULT '',
  22.   `rtime` int(11) unsigned NOT NULL DEFAULT '0',
  23.   `state` int(8) unsigned NOT NULL DEFAULT '0',
  24.   PRIMARY KEY (`id`)
  25. ) ENGINE=MyISAM DEFAULT CHARSET=gbk AUTO_INCREMENT=1 ;
