標(biāo)題: [求助] 升級(jí)mysql5.6.17后無法啟動(dòng) [打印本頁]
作者: viki    時(shí)間: 2015-12-6 20:24     標(biāo)題: 升級(jí)mysql5.6.17后無法啟動(dòng)
  1. 151206 19:46:32 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.6.17/data
  2. 2015-12-06 19:46:32 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
  3. 2015-12-06 19:46:32 23088 [Note] Plugin 'FEDERATED' is disabled.
  4. /www/wdlinux/mysql-5.6.17/bin/mysqld: Table 'mysql.plugin' doesn't exist
  5. 2015-12-06 19:46:32 23088 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
  6. 2015-12-06 19:46:32 23088 [Note] InnoDB: Using atomics to ref count buffer pool pages
  7. 2015-12-06 19:46:32 23088 [Note] InnoDB: The InnoDB memory heap is disabled
  8. 2015-12-06 19:46:32 23088 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
  9. 2015-12-06 19:46:32 23088 [Note] InnoDB: Compressed tables use zlib 1.2.3
  10. 2015-12-06 19:46:32 23088 [Note] InnoDB: Using CPU crc32 instructions
  11. 2015-12-06 19:46:32 23088 [Note] InnoDB: Initializing buffer pool, size = 128.0M
  12. 2015-12-06 19:46:32 23088 [Note] InnoDB: Completed initialization of buffer pool
  13. 2015-12-06 19:46:32 23088 [Note] InnoDB: Highest supported file format is Barracuda.
  14. 2015-12-06 19:46:33 23088 [Note] InnoDB: 128 rollback segment(s) are active.
  15. 2015-12-06 19:46:33 23088 [Note] InnoDB: Waiting for purge to start
  1. tarting MySQL... ERROR! The server quit without updating PID file (/www/wdlinux/mysql-5.6.17/data/ebs-48663.pid).
論壇的方法都試過了 還是沒法啟動(dòng) 老大出來看看吧,主機(jī)是西數(shù)的,預(yù)裝了面板
作者: haojielyb    時(shí)間: 2015-12-17 00:31
