標(biāo)題: [求助] wdcp3.x安裝后 后臺管理地址沒有綁定在ipv4上,求幫助 [打印本頁]
作者: billykinggym    時間: 2018-4-6 13:02     標(biāo)題: wdcp3.x安裝后 后臺管理地址沒有綁定在ipv4上,求幫助
我在阿里云的centos7中,編譯安裝wdcp3 的最新版本。
成功后,發(fā)現(xiàn) wdcp的后臺進(jìn)程也就是8080端口那個,沒有綁定到ipv4上,期望是可以綁定0.0.0.0.如下:
Active Internet connections (servers and established)
tcp        0      0 127.0.0.1:11211         0.0.0.0:*               LISTEN      7943/memcached
tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      31124/redis-server
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      7908/httpd
tcp        0      0 0.0.0.0:21              0.0.0.0:*               LISTEN      8011/pure-ftpd (SER
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1165/sshd
tcp        0      0 0.0.0.0:3306            0.0.0.0:*               LISTEN      7854/mysqld
tcp        0      0 172.16.25.199:22        112.10.136.88:12599     ESTABLISHED 2944/sshd: root@not
tcp        0      0 172.16.25.199:22        112.10.136.88:12746     ESTABLISHED 1301/sshd: root@not
tcp        0      0 172.16.25.199:43160     140.205.140.205:80      ESTABLISHED 1221/AliYunDun
tcp        0     40 172.16.25.199:22        112.10.136.88:12597     ESTABLISHED 2942/sshd: root@pts
tcp        0      0 172.16.25.199:22        112.10.136.88:12775     ESTABLISHED 1254/sshd: root@not
tcp        0      0 172.16.25.199:22        112.10.136.88:13194     ESTABLISHED 8156/sshd: root@not
tcp        0      0 172.16.25.199:22        112.10.136.88:13193     ESTABLISHED 8154/sshd: root@pts
tcp        0      0 172.16.25.199:22        112.10.136.88:12745     ESTABLISHED 1299/sshd: root@pts
tcp        0      0 172.16.25.199:22        112.10.136.88:13272     ESTABLISHED 1363/sshd: root@pts
tcp        0      0 172.16.25.199:22        112.10.136.88:12759     ESTABLISHED 1252/sshd: root@pts
tcp        0      0 172.16.25.199:22        112.10.136.88:13273     ESTABLISHED 1365/sshd: root@not
tcp6       0      0 :::8080                 :::*                    LISTEN      3026/wdcp
tcp6       0      0 :::21                   :::*                    LISTEN      8011/pure-ftpd (SER
Active UNIX domain sockets (servers and established)
unix  2      [ ACC ]     STREAM     LISTENING     15585    1221/AliYunDun       /tmp/Aegis-<Guid(5A2C30A2-A87D-490A-9281-6765EDAD7CBA)>
unix  2      [ ACC ]     STREAM     LISTENING     154007   7854/mysqld          /tmp/mysql.sock
unix  2      [ ACC ]     STREAM     LISTENING     9569     1/systemd            /run/systemd/private
unix  2      [ ACC ]     STREAM     LISTENING     11138    1/systemd            /var/run/dbus/system_bus_socket
unix  2      [ ACC ]     SEQPACKET  LISTENING     9608     1/systemd            /run/udev/control
unix  2      [ ACC ]     STREAM     LISTENING     15586    1221/AliYunDun       /usr/local/aegis/Aegis-<Guid(5A2C30A2-A87D-490A-9281-6765EDAD7CBA)>
unix  2      [ ACC ]     STREAM     LISTENING     6885     1/systemd            /run/systemd/journal/stdout
可以看到8080的wdcp綁定到了:::8080 而 0.0.0.0上卻沒有。
也找不到wdcp后臺的配置文件,不知道如何解決。
