----Install Error: php make err -----------
 centos  編譯安裝的時候出現(xiàn)了
有沒有可能是centos集成了阿帕奇的原因?
本文連接:http://www.ahbydz.com/old/node/900
盡量復(fù)制多一點(diǎn)的錯誤信息
?Thank you for using
 Thank you for using PHP.
/bin/sh /root/lanmp/php-5.2.17/libtool --silent --preserve-dup-deps --mode=compile gcc -Iext/date/lib -Iext/date/ -I/root/lanmp/php-5.2.17/ext/date/ -DPHP_ATOM_INC -I/root/lanmp/php-5.2.17/include -I/root/lanmp/php-5.2.17/main -I/root/lanmp/php-5.2.17 -I/root/lanmp/php-5.2.17/ext/date/lib -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/lanmp/php-5.2.17/ext/mbstring/oniguruma -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include/mysql -I/root/lanmp/php-5.2.17/TSRM -I/root/lanmp/php-5.2.17/Zend    -I/usr/include -g -O2  -c /root/lanmp/php-5.2.17/ext/date/php_date.c -o ext/date/php_date.lo
/bin/sh /root/lanmp/php-5.2.17/libtool --silent --preserve-dup-deps --mode=compile gcc -Iext/date/lib -Iext/date/ -I/root/lanmp/php-5.2.17/ext/date/ -DPHP_ATOM_INC -I/root/lanmp/php-5.2.17/include -I/root/lanmp/php-5.2.17/main -I/root/lanmp/php-5.2.17 -I/root/lanmp/php-5.2.17/ext/date/lib -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/lanmp/php-5.2.17/ext/mbstring/oniguruma -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include/mysql -I/root/lanmp/php-5.2.17/TSRM -I/root/lanmp/php-5.2.17/Zend    -I/usr/include -g -O2  -c /root/lanmp/php-5.2.17/ext/date/lib/astro.c -o ext/date/lib/astro.lo
/bin/sh /root/lanmp/php-5.2.17/libtool --silent --preserve-dup-deps --mode=compile gcc -Iext/date/lib -Iext/date/ -I/root/lanmp/php-5.2.17/ext/date/ -DPHP_ATOM_INC -I/root/lanmp/php-5.2.17/include -I/root/lanmp/php-5.2.17/main -I/root/lanmp/php-5.2.17 -I/root/lanmp/php-5.2.17/ext/date/lib -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/lanmp/php-5.2.17/ext/mbstring/oniguruma -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include/mysql -I/root/lanmp/php-5.2.17/TSRM -I/root/lanmp/php-5.2.17/Zend    -I/usr/include -g -O2  -c /root/lanmp/php-5.2.17/ext/date/lib/dow.c -o ext/date/lib/dow.lo
/bin/sh /root/lanmp/php-5.2.17/libtool --silent --preserve-dup-deps --mode=compile gcc -Iext/date/lib -Iext/date/ -I/root/lanmp/php-5.2.17/ext/date/ -DPHP_ATOM_INC -I/root/lanmp/php-5.2.17/include -I/root/lanmp/php-5.2.17/main -I/root/lanmp/php-5.2.17 -I/root/lanmp/php-5.2.17/ext/date/lib -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/lanmp/php-5.2.17/ext/mbstring/oniguruma -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl -I/root/lanmp/php-5.2.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include/mysql -I/root/lanmp/php-5.2.17/TSRM -I/root/lanmp/php-5.2.17/Zend    -I/usr/include -g -O2  -c /root/lanmp/php-5.2.17/ext/date/lib/parse_date.c -o ext/date/lib/parse_date.lo
cc1: out of memory allocating 16392 bytes after a total of 52121600 bytes
make: *** [ext/date/lib/parse_date.lo] Error 1
?Starting nginx: [emerg]:
 Starting nginx: [emerg]: bind() to 0.0.0.0:80 failed (98: Address already in use)
這里應(yīng)該就是系統(tǒng)自帶的apache在運(yùn)行的原因
?怎么把系統(tǒng)默認(rèn)的lamp卸載掉
?有相應(yīng)的腳本嗎
 有相應(yīng)的腳本嗎
rpm -e httpd*
rpm -e httpd*
?我使用了?rpm –qa | grep mysql
 我使用了 rpm –qa | grep mysql  列出來再rpm -e 才卸載成功了
然后yum update后重啟
然后用rpm安裝成功了  接下來試試編譯的
話說編譯的和rpm有什么不同?
基本上,是一樣的
基本上,是一樣的
?Shutting down MySQL........
 Shutting down MySQL........ SUCCESS!
   1:mysql                  ########################################### [100%]
Starting MySQL. SUCCESS!
/www/wdlinux/mysql/bin/mysqladmin: connect to server at 'localhost' failed
error: 'Access denied for user 'root'@'localhost' (using password: NO)'
error: %post(mysql-5.1.55-1.i386) scriptlet failed, exit status 1
============  mysql install error  =============
?卸載了還是出錯了 郁悶啊 checking for
 卸載了還是出錯了
郁悶啊
checking for specified location of the MySQL UNIX socket... no
checking for MySQL UNIX socket location... no
configure: error: Cannot find MySQL header files under /www/wdlinux/mysql.
Note that the MySQL client library is not bundled anymore!
----Install Error: php configure err -----------
完整卸載 rpm -e httpd* rpm -e
完整卸載
rpm -e httpd*
rpm -e mysql*
rpm -e php*
rpm包安裝還是出錯了
 提示
Starting php_fpm  done
error: %post(php-5.2.17-1.i386) scriptlet failed, exit status 1
============  php install error  =============
